SVT Spark Plug Cables Varies?
suma_
Dear friends and sifuus,
i bought a set of Ultra 8mm plug cables (5 pcs) to fit into my SVT (2nd generation).
the cables were taken from SVT, but not sure from with models.
it was a simple mistake coz not to try it first before purchase because i assume that cables should fit well into SVT.
but when i tried to plug into my distrbutor, it was not fit at all because the the size of the pin (both end) was about 2-3mm bigger than the stock one.
is the plug cable and distributor varies for SVT (1gen & 2gen)?
or the cables could be from other 4AGE engine? BT?
:confused_smile:
All the svt and bt cable doesn't care is 1st or 2nd generation, all " IS " the same. U sure u bought the right cable for svt???.....i got one set but it fit directly to svt and bt too....wonder urs..??
according to the seller, yes, it is from silvertop.
i haven't a chance to check with my cousin's svt and my friend's BT.
otherwise, i could confirm back with the seller.
