Thank you bro for the reply..but anyway distributor already replaced new before suspect because of the distributor.... by the way vtec is function well. I noticed my engine will suddenly shutdown if running for time period about 1 hour without stop.. i'm thinking it is look like temperature sensor..but dun know which sensor. The funny is that,the shutdown did not give engine check lamp..this make confuse more..![]()
tqsthe engine will suddenly shutdown during braking time after engine running about 2-3hours without stop..the rpm will drop and shutdown..i alredy clean throttle valve inlet at intake emm looks better than before that after running about 1 hour than shutdown..i'm thinking need to replace fuel pump later..is it ok..?anyway may be there are other problems related?tqs
Po
Its the gearbox solonoid. Anyway, congratualtion u fought the culprit.
the culprit of the reason for my car is....
the " D shape" thing inside it, I got it replaced and the problem gone. Located at the gearbox.
