sr20 neo vvl
KaiKon
anyone has any experience with this engine b4?wut is the usual problems, easy to get sparepart or not, performance wise? really appreciate 4 any advise.thinking of getting one soon...thx.:X-:
thats y laaa..a guy offered me for b13 wif sr20 neo..dunno la want to buy or not..scared if anything rosak...sangkut plak kete kat w/shop.
okla 18k for b13.. for tat engine. wat thing u scare before u buy u can take to some workshop check the engine is ok or not if not a big problem can buy it..
u better check as turbo engine are sensitive type of engine.. i'm using a sr20. get a good n trusted person 2 check if not later when u buy back got problem u need a lot of cash 2 settle it
my U13 had problem with SR20 NEO
hi evening everyone...
i've covert my U13 SR 20 DE to SR 20 VE (NEO VVL) tiptronic....after the engine converting process pass, i've had problem when shifting using the CVT gearbox....so i convert my gearbox to the SR20 LSD.....
but now....after converting the Gbox....i got one more problem now....when the car stopped, i can rammed my car up to 7500 rpm....but when cruising......when the RPM reach 5000....it cut-off automatically......and needs to shift to another gear, so my Neo cannot be operates....Noe can be able to operated when the RPM reach at 6200 rpm....
harh???
ur electrical problem...
Neo engine is a very powerful engine on NA based...
try read more review from new zealand and australia...
they have a lot of those engine in their cars...
these halfcuts are very very expensive
all performance car are expensive.. if you intend to play around with tat car then u must have extra cash if not there wouldn't be ending story..
U SO UNLUCKY.. I HEARD YOUR PREVIOUS ENGINE WAS SR20DET
NEO VVL IS horrorble engine must stay standart wiring and meter to activate VVL
maybe u must use the original CVT gbox to settle back the problems
anyway goodluck
just my 2 cents
But last time i read in 1 magazine say that if ur SR20VE CVT system gt prob just find 1 SR16VE CVT system board to install in can already! But nv try this engine b4, so this is the magazine comment... :embaressed_smile:
Bro, I have did the same as you and i had the same prob but the solution is easy, just ask your mechanic to wire you gearbox wiring so that it shows the car is on D (drive) all the time, then you wont have this prob. Hope this helps.......
