SR20 Neo VVL into B13
rapinsoul
No more SR20 now its SR16 Neo VVL into B13
Hi Guys,
My current ride Sentra B13's engine is giving up and i am planning to go for a SR20 NEO VVL Swap.
Can a SR20 NEO VVL fit into B13 without any issue and major modifications like mounting and other?
My current engine is a automatic and the SR20 is manual.
Kindly advice, thank you
B13 is like Genting Taxi rite???
i remember saw one racing car in Malaysian Super Series category S16... :ADORE:
http://a3.sphotos.ak.fbcdn.net/hphotos-ak-snc6/150811_463674703444_713843444_5841002_2120494_n.jpg
rapinsoul: SR20neovvl never ever comes or produced with manual gearbox. they are only available with hyper cvt gearbox. whereas SR16neovvl never ever comes or produced with auto gearbox. it comes standard with manual LSD gearbox.
you stated that your SR20neovvl was manual. i am assuming that it is converted to manual gearbox, and it is not in a form of halfcut.
p/s: speaking of halfcut..there are three versions of SR20Neovvl halfcut. the P11, the U14 and Y11. which one is yours?
pomengtr: yes..he's one of my friends..he owns a bengkel at subang 2. exceptional job in nissan engines
sr20ve = front and rear mounts into crossmember fit right on, you will need to fab the passenger side mount, tranny mount may or may not be fabbed depending on your tranny choice.
you can use an sr20de or sr18de manual tranny and axles and a DE ecu, using any switching system to activate the vvl solenoids
Sr16ve with manual lsd tranny bolts on to the b13 no problem.
we just did a swap, check it out
Tevs
http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs467.ash2/74055_458774398521_528473521_5401587_3290059_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs457.ash2/72995_458774178521_528473521_5401574_3549684_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs471.ash2/74432_458774013521_528473521_5401563_7472826_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs983.snc4/75596_458773838521_528473521_5401559_779042_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-snc4/hs980.snc4/75382_458774323521_528473521_5401583_1960672_n.jpg
http://sphotos.ak.fbcdn.net/hphotos-ak-ash2/hs444.ash2/71792_458774223521_528473521_5401576_1235823_n.jpg
dunno where it came from, but thanks for answering the question MKMD428.
LSD tranny for sure, had to replace the mechanical speedo/gauge panel into an electronic type in order for us to rev beyond 6000RPM, now she revs happy beyond 8K
Hi All thanks for advice, after considering very carefully i made my mind and i bought a N15 Halfcut not very sure on the LSD part, will update the progress here soon.
i have a question, can we use the cross member from N15 in the B13?
---------- Post added at 03:02 PM ---------- 6 hour anti-bump limit - Previous post was at 02:38 PM ----------
Here we go, pictures are as below the day when we start the engine before paying off
http://img219.imageshack.us/img219/8172/21102011.jpg
http://img535.imageshack.us/img535/3411/211020111.jpg
http://img87.imageshack.us/img87/2478/211020112.jpg
all SR16neovvl halfcut comes standard with viscous LSD gearbox bro.
N15 is plug and play 100% to your B13. so no worries and less hassle.
Thank you chief :biggrin:, the car should be out in a day or 2, one thing which is in my head and making me to think again and again is the exhaust setting, for now i am going to stick with the original piping which is in currently from the previous engine, what size piping should i use?
mine was with 2" diameter. not too small for low end and not too big for hi end.
if you have future updates in mind (big ones) consider a 2.5" diameter.
most of my friends are running 3.0" diameter. but then again, the stroke itself has been 1998cc.
sounds absurd? no bro...it's proven..
:biggrin::biggrin::biggrin:
i think i am the first one starting this at Malaysia after reading some US forum feedback
and people told me i am sohai
and now it a trend
Hi all, below is the current situation of the car. Yesterday we did a test, car starting no problem, no sound at all. however in the meter panel the Air Bag and ABS light is on, and when i asked the meck, he told that he can remove the ABS light but cant do anything about the Air Beg because it connects to the Air Beg sensor, anyone of you who convert SR16 from N15 to B13 had this issue and can i know how you guys solve it?
http://img23.imageshack.us/img23/3518/dsc00896se.jpg
By rapinsoul at 2011-11-02
http://img15.imageshack.us/img15/6596/dsc00897hf.jpg
http://img718.imageshack.us/img718/1010/dsc00899cf.jpg
http://img256.imageshack.us/img256/4914/dsc00898vn.jpg
the ABS light and Airbag will on
Airbag on due to sensor issue.. normally people just remove the bulb only
ABS is due to you not able to refit all the ABS sensor and connector to your car
to refit you need to have B13 ABS knuckle and pull all the ABS sensor and tap it
mostly for halfcut. the ABS sensor is cutted
so to solve this problem is same. remove the bulb saja
:biggrin:
:biggrin:
thanks brader cmng, the front sensor is attached but in my case the rear is drum break originally, now i have to source out for a N15 Rear disk break
you need to have B13 Rear disc brake with ABS sensor
for me my advise get rid the ABS
it give you major headache also
i not a fan of ABS and i prefer without ABS as well
just get B13 Rear disc brake with knuckle only
nowday got some people mod N15 knuckle on B13 but by welding method
front i am using brake calliper, knuckle and disk from the N15 half cut so if i put rear from B13 i have to buy 2 separate set of brake pad am i right? is a N15 Rear brake set pnp to B13?
Front N15 is plug and play to B13
Rear N15 is not plug and play.
as you mentioned you still using drum
you need to get B13 Rear Disc brake knuckle
many i know use malaysia boleh style which is welding method
Do your halfcut doesnt come with N15 Rear disc brake ?
