apexc said:what type of signal that RSM receive for the vechicle speed.
volt - 0volt to 5volt
mA - 4-20mA
pulse
answers will be very appreaciate.
thank u
apexc said:no i would like to install the RSM to my car.....citroen.....from what i know my speed sensor will give output in volt....
sensor is a three wire sensor.....
1. ground
2. 5 volt reference from ECU
3. signal to ECU ( as i say above....signal might be in volt )
MR. Zaki any expereince in installing one in the conti cars....?
Speed sensor
The sensor is Hall effect based and produces 8 impulses per rotation, or approximately 5 impulses per meter traveled (this depends somewhat on tire size). It is located on the gearbox where the speedometer cable attaches, or in some versions, on the cable itself.
not the printed one :)zaki said:I think I have the printed doc. I'll email it to you tonight.
