Convert wasted spark to Sequential Ignition
nan83
hi....
just wanna share some info ...
4g63t now can convert our wasted spark coil to sequential without changing to standalone ..
we can use devices below :
1. M&W Pro-14 Evo & Pro-Drag Evo ... ( quite expansive huhu)
2. Okadaprojects Plasma Quad PAC
3. EFI Technology IMU Ignition Multiplexer (dunno can work or not, mybe need haltech to generate distributor signal)
4. Hondata Coil Pack Retrofit[CPR] (this also need distributor output signal = single wire ignition output)
what i interested now is hondata CPR... not so expancive huhu.. my e6x can generate distributor signal. But the hondata cpr need SYNC or HOME signal from S300 ... What i wanna know is what type of signal S300 generate to feed to CPR ... reluctor signal or 5volt square wave signal??? if square wave, it should work with 4g63t cam sensor.. anyone can confirm this?? coz 24-1 honda distributor sensor give reluctor signal... just hoping s300 sync output is square wave....
hummm... still have other method to do this??
thanks all...
