RPM Tuning
edwin_lcw
anyone knows how to tune the rpm meter of wira 2004 ....... today i met huakenny go see my car engine ...... see weather go the hole to tune it ...... but cannot find larr ..... maybe the engine diff from the wira 2000 ....... but anyone knows whare is the tuning part ?
use computer to tune lorrr...go jln ipoh bt3 BP......
sismen mahhh...nathing can tune lorr..trotle body n distrbutor also cannot tune liao.
huakenny said:
that is a ECU DIAGNOSTIC TOOL......to diagnose car problem n reset ecu as well.....can detect any problems of ur car
Not ANY PROBLEM lar.... engine related only.. and only if it triggers an error code....
dirty injectors cannot detect (unless they are badly stuck)
dirty FPR cannot detect, unless it's fully stucked
dashboard rattling cannot detect, unless .... PDT = Pandang Dan Tengok
u know my car now drive drive half way when prss the clutch the rpm meter go down till die off ....... now every time must press oil ....... like dat i dunn how long i can still support ........ petrol also gone a lot
go get yr tb cleaned/service... if u need to change the steppermotor gears, do so...
only cost arn 20bucks....
Oops...missed something...can detect any problem tat has sensor there..... :)
drexchan said:
Not ANY PROBLEM lar.... engine related only.. and only it triggers an error code only....
maybe got some vacuum hoses lose oledi or leaking....anyway...RESET ur ecu la..see can help or not.....n clean ur TB..as i told u b4...go jaya jusco or any nearby spare parts shop..get one can carburetor/choke cleaner n spray to ur TB inside..clean it.....it might helps...
RESET ecu....if stil cannot..then only clean TB...
how to reset? disconnect ur negative side battery terminal for bout one hour....then connect it back....n start....let's ur ECU re-learn....
i hav this same problem........ :banghead:
