hi,
check carefully around the door switch.there is a black rubber tap covered the switch.take it off then you will see the switch.find the wire out but remember that the switch only for POSITIVE wire(+),fix the NEGATIVE(-) wire at any metal screw will do...keep in touch if you don't understand what am i talking about...
