Radiator Fan Problem
natureguy
my car radiator fan wouldn't stop after i turn off the car... any1 can tel me where the problem.... stock gti........ is tis the heat sensor spoil? of the fan spoil? i din modify it at all.........
do u mean it NEVER stop although u TOTALLY switch off the ignition ?
if u totally switch off then no more battery power mah....
Really Need Helllpppp!!!! Serious Problem!!!!!
i turned off d car n have took out d key ady. then, suddenly d radiator fan turned on itself and it would not stop.when i took out d relay of d radiator fan from d fuse box,d fan still continue to run by itself. the fan keep on running till my car battery run out. i have to start d engine,turn on d air-con;then turn off d air-con and off d engine car,then only d radiator fan would stop. HELLLPPPPP!!!!!!!! PLEASE!!!!!! NEED HELP FROM PRO_WIREMEN!!! anyone faced this problem before??
For your case, I think the radiator fan is now bypass the ignition swicth to get the power supply. Maybe you can check the wiring or the fan relay.
