Remove fan radiator
sakos
Question
1. Fan radiator got sound once running. Suspect the fan is bot balance/equal. Do I hv to change the fan or motor? Price
2. Can I remove the fan without removing the radiator?
p/s my car satria old model
got nosiy?tighten nut/bolt...if confirm motor problem.
replace it from new or used kedai potong cndition..how le?
of coz need move radiator...or if u enough skill normally it can remove fan or motor without remove radiotor..but hard job...easy is remove all...u enjoy d work can learn something new but step by step...
change the motor only.....
the fan blades should be ok. better remove the whole radiator, only bout 4 screws only,
not much of a hardjob......
Kawtim, replaced with new motor only coz before buy the motor I test without blade the weird sound still there so confirm motor/bearing kong. Cost me RM40 and DIY without removing the radiator.
TRy 2 diy...its take bout 30 min or less than an hour rather than waste d money sen it to wrkshop. No need remove radiator,juz remove the fan frame.
Juz tel them fan motor to spare part shop. Bttr bring along the motor so they can look 4 it more easier according the length of each screw hole.
@ bro sakos
do the motor available in spare parts shop? What is it called?
PH Auto Enterprise
7 Jalan 21/17
46300 Petaling Jaya
03-7877-2288
Mine prob is motor for radiator fan. I called them earlier to get the price. I bring oso the spoilt just in case. Original/ branded motor price is RM100
