Question:Wheel spacer
ealt
2,000 RPM
Hi MLOCian;
My rims offset are 40mm and will be soon convert to E5 bodykit.Can anyone help me with the wheel spacer that should i put on front and rear wheels..What the best inch should i fit onto my wheels.Thanks
ealt.
Currently your car is with 114.3 x 5 or 114.3 x 4?
If you not planing to install Brembo, you can looking for deep offset rims to make it fit to your bodykit.
By the way, the thickness for your car should be 1" & 1 1/2". :)
Again, the thickness will be different due to the rim spec u use.:_:
if planning to use spacer.. 1inch is a good size.. but bare in mind that it will be heavy a bit lar!! unless its alluminium...
Front or rear for 1inc.got offer but 2 pieces are 0.75inc and other 2 1inc...can ngam or not...
