Airtrek wheels question
carnetics
Anyone know if a 18x8 +45 wheel will cause any problems with fitment? I'm running 17x8 now but don't know the offset. Should I run spacers? My concern is that the wheel might sit too far in and rub against something. Anyone know what the stock rims offset is?
OK thanks guys will check the calculators. I'm using BC gold coilovers so the shock body shouldn't have a problem clearing the wheel. Maybe will run spacers if got any problems with clearance. 10mm spacers.
I was running 17x7 with +40 offset which should be fine, however, sometimes it is not the rim but the tyre. I was running 235/50 rubber (to give some sidewall flexing and improve ride) and they rubbed very slightly on front plastic liners. It is a simple calculation to compare how much closer to the centre of the car a particular rim/tyre combo is would be.
Assuming you go +45 then simplistically that is 5mm closer to centre of car than I was running so your tyres would need to be 10mm narrower (225). someone can please check my logic but if std offset is +46 then your issue is likely not the rim but the rubber...
---------- Post added at 12:37 PM ---------- 6 hour anti-bump limit - Previous post was at 12:34 PM ----------
Actually, I forgot the rim width was 8" so your rim would be 17mm closer (not 5mm)
The bit about tyres still stands (i think)
