Question on Toyota LE suspension setup,.
kenken
Hello eeveryone, I'm asking this on behalf of my friend. He has a Toyota LE with 4AGE 16v running 14" wheels. During high speed (h) and acceleration the car is very unstable. Any advice of the suspension setup? My friend prefers comfort more to performance so I think a set of sport springs and new abs will be appropriated. THANKS. please help.
try using the gas absorber for both front and rear. You can get it from spare part shop. Better go for original Toyota brand (Kayaba). If you want confortable ride, do not change the coil spring, what you can do is use the corona coil springs, there are same with the LE configuration. But maybe its stiffer cause its use to hold 1.8 engine capacity. So for your 1.6 will be no problem..
but the best is still using adjustable...
