Suspension setup for myvi
My absorber is almost done ady. Im now looking for a suspension setup that is handle and ride better than the standard setup. I prefer stock ride height or lower a bit also can. My budget is around 1k. Any suggestion?
Currently, Im thinking of the APM absorber + Tein S Tech spring. Is that ok or any other setup better than that around 1k? or only change the absorber?
Seems like a nice setup. I search over the internet sees good comment on the absorber n its cheap too. Thanks =)
Yup. I prefer stock ride also. Lower also can but not too low. Mine stock SE pass the bump already will kena the bottom when carry like 5 ppl in the car.
Anything but G|A|B because the springs are quite harsh on Malaysian roads, am a user of G|A|B SS fully adjustable, feels great when you drive on track or touge but normal drive will be a back braking experience LOL~
For adjustable , please consider on your setup tuning before complaining on the brand .
Most compact brands patent on most absorber these days . They followed very similar design everywhere .
Its just that the type oil were use for damping .
adjustable suspension...just use 1 step lower spring rate than the "out of box setting" can ask to change for free before installation on certain shop...
Currently I'm pairing GAB sport springs with IMP Comfort absorbers, not too bad and not the harshest setup. I believe if you pair progressive springs with IMP Comfort absorbers you should attain quite good comfort and performance.
For eibach springs :
Just look for the Red springs for Myvi (Ranges around 800-900+ in market)
For SACHS:
Look for super touring absorbers for Myvi (Ranges between 350-400+ in market)
for installation and alignment (tyre shops usually charge between 150-200 for springs and absorber installations, alignment around 30-50)
Hope this info helps.
If you still have budget i recommend getting a front UR strut bar as well to further increase the cornering rigidity. 160-200
then u top it off with a Brembo OEM discs 250-290.
Regards and have a nice day
For SACHS:
Is your current car on this setup? I've heard that eibach+sachs is good but I dont know how good it is. Would love to see one myself haha
Ah? I thought all Eibachs were black?
Happen that day looking at Eibach website, got black, red and even blue.
Black is Pro kit
Red is sports line and lowering
Blue for competition, something like that.....:driver:
---------- Post added at 10:35 AM ---------- 6 hour anti-bump limit - Previous post was at 10:33 AM ----------
For SACHS:
Sachs super touring are normal length absorbers, right? Does it go well with lowering springs?
