Problem with Civic EG(SR4) local.
R.C.
My car SR4 (EG) has this problem : The engine will died off if I turn on the air-con. the rpm will drop to around 200 only ... and eventually K.O.
I've cleaned the throttle body, bought a new idling valve, new ditributor(power).
Is it really the compressor ?? or what. I've dump in too much $ for the unknown problem already.
Thanks.
check also all vacuum hoses. i think sumthing to do with idle controller. for carburettor, u can set engine rpm higher...got separate screw for acond idle adjustment.
Thanks.
check your ISC. so rich lah u change this change that distributor where got connection with idling problem?
