I've recently encountered a problem with my turbo timer type-1, the old type with silver casing, blue& red color, not the new type with black casing and white color.
Previously i switched to Voltage mode for more than 2 weeks since after my previous battery dead and i change with a new battery, in the same time, relocated my battery to rear trunk.
Until today, i switched back to my timer, and set for Auto. And i was wondering how come my timer never increase but only hold at 0.00 sec, while the "A" flashing constantly all the time even low or high rpm after sometime driving. I then try set to 0.30sec, and it works fine.
So i try to check on the RPM option, and the RPM is at 0 while engine running. Wire checked, no loss, got electric supplied (checked through test pen).
And checked with the Speedometer as well, and is not working too! Wire checked, no loss, got electric supplied (checked through test pen).
Summary
Turbo Timer Manual - OK
Turbo Timer Auto - NO (due to RPM reading not functioning i guess)
RPM Reading - NO
Speedometer Reading - NO
Speed Measurement as in 100/200/400, 0-100, etc - NO (due to Speedometer reading not functioning i guess)
Voltage - OK
Is that possible that the main device is malt-function? or wire part?
Summary
RPM Reading - NO
Voltage - OK
