DIY - Apexi Turbo Timer Installation
Speeder
Dear all DIY specialist,
I just buy a Apexi turbo timer (pen type which can show A/F, O2, Battery & Timer) and would like to DIY installation it to my car (Wira 4G15 SVDO).
Have anyone here can teach me how to install it? Especially A/F wire and O2 wire connect to which wire of car?
Thank you.
the shop i go to, bloody wanna charge me RM90!!! then nego till 55...wat a rip off .....
bro speeder,
Don't risk DIY the wire connection, better go to a shop :)
bro if you to install O2 sensor and A/F for pen type turbo timer...i prefer to you to go to specialist shop because 02 sensor and A/F must take from the ECU.....
O2sensor/AF can tap directly at ur stock exhaust sensor....
dat's a easier/lazy way to do it la...
if u got ur ecu wiring diagram, then its not hard to locate the pin....
really can direct connect to stock exhaust sensor?
That's why I need the ecu wiring diagram.........
Can somebody share with me?
i also use apexi pen type turbo timer.....but A/F and 02 sensor i don't use it because do know where to take it or tap it...because some of my friend said 02 sensor and A/F cannot do a tap2 like we tap at the timer wiring.......
so i also try to find ECU diagram for perodua viva.....
If cannot do the tap, so what can do? soldering?
Wira 4G15 SVDO with custom turbo kit?
NO? Then need turbo timer?
---------- Post added at 12:32 AM ---------- Previous post was at 12:19 AM ----------
Anyway... here is the link...
blog.autoworld.com.my/index.php/.../ecu-pin-out-assignment
BR
