Powerzone LSD
GSR_Freak
I saw your LSD product ad in the hypertune magazines, would like to know whether you have the lsd for 4g93t gsr 4wd(locked to 2wd) gearbox, do i retain back my driveshaft or i have to custom made 1, and how much would this cost, i roughly read a few lines of your explaination in the hypertune magazine regarding lsd, is the 1 that you are selling, clutch base type lsd?
Also same question goes to a proton saga 1.5 with stock gearbox.
thanx
We're not sure about the GSR 4WD box, do you know the code that's stamped on the side of the box. It reads something like F5Mxxxx.
On the Saga 1.5 we've ready stock of the LSD kit.
Fitting the LSD involves removing and dismantling the box. The driveshafts remain unchanged.
This LSD kit is of the clutch type, full functioning 2-way locking.
Originally posted by jeremylj@Feb 26 2005, 16:19
quote me the price for waja....kaaz was RM3K..
It's RM575 with installation. But it's not the same as Kaaz...ours is a friction type, so don't expect the same results.
Maybe you guys could offer a few different spring rates for your LSD to suit different applications. Just a small suggestion.
Hi there Powerzone,
Can you explain more on this quote "This LSD kit is of the clutch type, full functioning 2-way locking." Is your LSD the same as those found on OEM LSD gearbox? I will try to get the number of my gearbox later and pm you later, as i assume you need to custom made 1 for my gsr box. But hopefully the price won't differ that much. And since some 1 brought up Kaaz, whats the diffrent between Kaaz and your friction type? hmmm with all the question, should decide to drop by your shop 1 fine weekend.
Originally posted by Powerzone@Feb 28 2005, 15:01
Yes, we can do one for Kelisa. Price is pretty standard for most cars at RM575 with installation.
[snapback]774527[/snapback]​
OH standard price rm 575...but u want to charge me rm650..... https://www.zerotohundred.com/forums/style_emoticons/default/dry.gif alt='dry.gif' /> ??? :huh:
Originally posted by GSR_Freak@Feb 28 2005, 10:58
Hi there Powerzone,
[snapback]775440[/snapback]​
Briefly, ours is similar to OEM multi-plate clutch type. It's friction lock.
Kaaz is using the worm gear type that locks with opposing gear action and is torque sensing.
kelisadetomaso said:
my car got default factory Mira L200 LSD
i just want get my LSD service.. how much? including workmanship
Sorry, we can't service it unless we can get the parts or service kit for it.
