LSD gearbox
crocky
Sifu,
May i ask what r the advantages of lsd gearbox? Does it still do the job even 4wd is being locked to 2wd?
thanks
hai crocky! as the name says...Limited Slip Differential.
LSD is used to prevent unnecessary slip, better traction. can feel a bit heavier though and u must use thicker oil, always known as LSD oil. never use 140 grade oil normally for rear differential for LSD.
nanti cepat rosakk....
Yup, also curious what is the benefits of an LSD gearbox ?
Looks like a lot of performance car and also those angan angan performance ppl looking for LSD gearbox.
Actually, can sifu sifu sekalian share with us why an LSD is so important ? Pros & cons ?
Originally posted by carcass+Apr 5 2005, 10:31 -->
QUOTE(carcass @ Apr 5 2005, 10:31 )
--QuoteBegin-Putra3
@Apr 5 2005, 09:24
hum,.interesting ,, can i know how much is the market price of lsd for evo 3 ah??
[snapback]869271[/snapback]​
RM1800 with driveshafts
[snapback]869543[/snapback]​
[/b][/quote]
thanks for the info
if you like to race on roads like genting or cameron highlands, then you will LOVE LSD... LSD also balanced up your car traction
resulting tyre worn up very fast :D
1 way = differential locking up under accel
1.5 way = diff locking up under accel and decel (partially)
2 way = diff locking up under accel and decel
full lock = always lock.. no matter on/off throttle
Originally posted by Jusoh@Apr 5 2005, 17:35
on evo7,8,9...uses SAYC...same kind like LSD...
correct me if i'm wrong... https://www.zerotohundred.com/forums/style_emoticons/default/rolleyes.gif alt='rolleyes.gif' />
[snapback]871069[/snapback]​
yer ker, SAYC as i know it is the anti yaw control which is the electronics that is used to control the evos body from yawwing when taking corners.. if u are talking about traction control, its like apple to orange.. as the LSD is mechanical while the traction control is electronic..
my 2 sen lahh..
Originally posted by tajulsans+Apr 5 2005, 20:47 -->
QUOTE(tajulsans @ Apr 5 2005, 20:47 )
[/b]
my 2 sen lahh..
[snapback]871622[/snapback]​
[/b][/quote]
yup....SAYC is to control the evos body yawwing when taking corners...while LSD control traction when car start moving from static...but LSD also distribute force to right and left wheel when car taking a corner either in accel mod or decel mod...just like AYC operate...i think SAYC and LSD have a same function....but AYC is trademark for Evo instead LSD for major car...same like ATESSA trademark for GTR...all i had learning from game GRAN TURISMO...huh...btol ke penjelasan aku....correct me if i'm wrong...
:D
Originally posted by Seraph@Apr 5 2005, 20:51
LSD for 2WD FF cars is only for front wheels then, rite?
[snapback]871632[/snapback]​
FF and FR 2WD is called LSD... 4WD i think is AYC because not too sure about the function
Originally posted by aja@Apr 6 2005, 07:04
For Honda Tyre R, what is the easier way to check the car got LSD or not?.
[snapback]872662[/snapback]​
some says jack the front car and spin one wheel.. see the other wheel whether it spins also or not?.. correct ah?.. :unsure:
[snapback]872704[/snapback]​
AYC is not for ordinary 4WD car but it's like trademarks for Evo's...like ATESSA for GTR's...correct me if i'm wrong... :rolleyes:
