Pls help~Drive shaft cover problem
(ADVAN)
Hi, im driving a satria mivec 1.8..i only drive this car once a week and the journey is less than 150km. However, my drive shaft cover repeatingly fell off / split into 2 after everytime i drove my car and i changed the cover every week!! I has been changing drive shaft cover from cheap to RM70 per cover and yet the problem wasnt solved yet.
To cut the story short, any reason / solution on the above problem?
Hi bro, it might be something had slashed or cut it opened when taking tight turns. Please check surroundings while have your car jacked up; turn right check turn left check.
Other than that, cover position might be a little out where the cover was stressed during tight turns.
Just my little opinion... :love:
1 side or both?
jack the car up, start the engine and start steering yr wheel left and right and accelerate like u r doing on wheel balancing...must be some friction there with yr body.....if not it wont crack juz like that....my 2cents...
