all toyota bro here, if your drive shaft kong, dun buy recon drive shaft, waste your money and give a lot of problem. recently i changed my drive shaft, the used parts guy recommend me to buy the recon drive shaft, cost me RM250 two side, after used for below two weeks, the recon drive shaft got problem (two side), i complain the used parts guy, he ask me go to his formen check, after check he only allow me to change left hand side drive shaft(same recon part). i already not happy with it.
After used for another two month, the left hand side drive shaft problem again, i change it to japan oem drive shaft, but after one more month, the other side right hand side drive shaft(recon) problem come out, the tire will jump around 80-90km and the car run to left hand side, at first i thought it balancing and alignment run out, so i do balancing and alignment, but problem still there, then i thought maybe the sifu not prof, so i change to other workshop to do again, same problem come out, i do balancing, on-wheel balancing, change front tire to rear, add camber, problem still there, at last, i change the recon drive shaft, problem solve.
my advice, never change the recon drive shaft, use back your drive shaft and just change the japan head, second choice is use japan oem drive shaft. dun ever try to use the recon lau si one.
