Pimp my ride featured "Jackhammer"
Hey, on the US version of Pimp My Ride one time they fitted a car with a HUUUUUUUUUGE sub.. called a Jackhammer, or at least thats what they said it was called, any idea where you could get something that size, power, ohmage, and for how much?
This one???
http://www.mtx.com/caraudio/products/subwoofers/jackHammer.cfm
Damn Gila SUB woh.... 22" IT's bigger than my RIM!!!
Specs:
* 6,000 RMS, 12,000 peak music power
* 23" tall
* 369 lbs.
* 900 ounce strontium ferrite magnet with extended magnetic field gap technology
* Carbon fiber and glass fiber dust cap with aluminum honeycomb center
* Expanded polypropylene cone with mica filler for reduced mass and increased stiffness
* FEA designed progressive roll spider with 10 AWG integrated tinsel leads woven in to allow for 2.5†of linear cone movement one way
* Aluminum shorting ring
* 6.5†voice coil with 17 AWG high temperature aluminum wire in a flat wound, long-excursion design incorporating 2.5†of Xmax
* Aluminum heatsink to maintain the optimum voice-coil temperature
* Replaceable cone kits available to switch between SQL & SPL models without removing the JackHammer SuperWoofer from its enclosure
That is the biggest paper weight in the planet. Seriously it didnt even manage to hit over 150Db on their demo car and has a 6" VC which support up to 6000w and a very weak motor.
