JackyII Known Member Senior Member Dec 7, 2006 #1 Hi, anyone here care to explain the difference(s) between using this and the original rubber mounting? can it fit with any brand of adjustables/coilovers? thanks! Last edited: Dec 9, 2006
huakenny LB Performance Senior Member Dec 9, 2006 #2 original rubber is comfort n silent type...canot use to adjust anything... pilowball mount is slighlty noisy after sometimes n it can adjust chamber....most adjustable suspension r using pillowball mount.. my2cent
JackyII Known Member Senior Member Dec 11, 2006 #3 thanks for the info. some people said if using adjustables w/o pillowball mount might causes damage to the chasis since the spring is harder/stiffer than the original ones and the rubber mount can't fully support it. how true is this?
N nclim 500 RPM Senior Member Dec 11, 2006 #4 well... adj without pillowball with spoil your rubber mount... so better for front adj, change to pillowball mount.
M mengz 500 RPM Senior Member Dec 11, 2006 #5 the pillow balls mounts will ensure that only ur shockers do the damping and not ur mounts as well.
