Pillow ball mounting
JackyII
Hi,
anyone here care to explain the difference(s) between using this
and the original rubber mounting?
can it fit with any brand of adjustables/coilovers?
thanks!
original rubber is comfort n silent type...canot use to adjust anything...
pilowball mount is slighlty noisy after sometimes n it can adjust chamber....most adjustable suspension r using pillowball mount..
my2cent
thanks for the info.
some people said if using adjustables w/o pillowball mount
might causes damage to the chasis since the spring is harder/stiffer
than the original ones and the rubber mount can't fully support it.
how true is this?
well... adj without pillowball with spoil your rubber mount...
so better for front adj, change to pillowball mount.
