Perdana v6 problem
dreamZz
at 1st, hapi depavali~! Jz wonder why my perdana v6 the oil symbol(like aladin cup) at dashboard meter there sometime it display when ON the switch.(which is normal) then after ignite the engine it gone which is expected. BUT UNFORTUNATELY most of the time the oil symbol is not display when i turn on the ignition switch. jz wonder whether sensor or wires shocked.
any 1 experience tis b4? :(
have u checked whether the oil level is sufficient? most often, if dis light only occur at intermitten interval, its contact issue. please check whether the oil pressure sensor is tightly in place sir
Hi xtremeleo bro, thx for replied. Did check the oil level which is in sufficient level. May I know how to check the sensor wher does it placed? U're Perdana owner as well? Thx man.. :-D
get a mech to check for you, dont fiddle the sensors yourself, get an expert to check it for u....or go for MUT scan.
