Hi all,
Offering the following NEW items when u service ur Perdana V6.
Timing Belt Kit Set Dayco(USA)rm300, local MMC rm220, Gates- out of stock
Air-con belt rm20, Fan belt rm24
Bosch Double Platinum Spark Plugs for V6 rm32 per piece. Mkt price rm45+/-
Plugs long-lasting will go up to 100,000km no problem
Perdana V6 Pro-Rallye plug wire From USA& together with grounding cable
already. rm220. Plug wire is 10mm. Good performance
Perdana Black Based Cyrstal Headlamp rm480 for a pair.
Perdana V6 ATF filter & gasket-rm87 Original Proton
Mitsubishi ATF oil SP111-rm25 per litre
---For this item, better uses back original and not cheap product cos it is
ur gearbox we talking about. Expensive to replace.
Perdana V6 water pump rm105
Castrol magnatec together with Bosch oil filter rm82
Also have German-imported 5w-40 oil 1 Litre- rm22 used by BMW & Mercedes
4Litre= rm88
Bosch Perdana Wiperblades-rm27
Bosch Perdana Brake Pads front rm41, rear rm45
Absorbers front rm80per side (oil), back rm80 (gas)per side.
outside selling rm100++
Proton ATF oil rm19 per bottle (use 4 bottles)
Local Perdana Air Filter-rm13
Bosch Alternator for V6-rm195
Front wheel bearing-rm122 per side made Japan
Rear wheel bearing-rm145 per side made Japan
Lower arm- go see ur mechanic first
Driveshaft head rm195 per side
Perdana outer door handle front-rm160 Original Proton per side
Battery for Perdana V6(NS60)-rm125 non- maintenance free
Perdana Door Visors- rm100(big), small rm58
Buy any of the above from me, sell u the following at
Hella twin-tone Horn rm39 per box( with relay)
Bosch twin-tone horn rm35(without relay)
Osram H4 60/55w rm9 each
Osram Cool Blue 60/55W rm49 a pair
Bardahl oil treatment,1 can- rm12
Ate Brake Fluid DOT 350ml -rm12
Castrol TQ-D 4L-rm40
Bosch Dot4 Brake Fluid 1 litre-rm19
Other parts will be updated time to time
Please contact:
012-2908159
Discounts available
4Litre= rm88
Please contact:
012-2908159
Discounts available
