Perdana V6 problem - Help me please
gotdamsg
I don't know what's the real problem here. The RPM is too low, all the lights, radio getting dimmer.. sometimes the radio on and off, the voltage seems to be unstable.
I just changed to a new battery last 2 weeks. So battery is not the problem here.
May I know what the cause here? I never encountered this before. please help.
have you check your alternator? The problem might come from there most likely as I experience this before.
Alternator not working efficiently all the time, especially during decelerating as I noticed my Volt Meter shows the voltage go down dramatically and then go up a bit when accelerate. Sometimes won't go up also.
Hence as you said, rpm low, dashboard lights & radio getting dimmer. Alternator not producing sufficient voltage enough to run the devices. No matter how many batteries you change also no use, the problem will still be there.
Solution: Change alternator.
hmmmm.. how about ECU? is this the symptom of failing ECU?
---------- Post added at 12:10 PM ---------- 6 hour anti-bump limit - Previous post was at 11:15 AM ----------
I will bring to shop soon.
---------- Post added at 12:13 PM ---------- 6 hour anti-bump limit - Previous post was at 12:10 PM ----------
Thanks for the solution..
