Painted CF can make back into CF clear ?
YEN96
anyone can advise me if a CF hood is already spray painted with colour, can i sand to remove the paint till CF then clear over for original CF look ??
YES. You can. Last time I bought a SEG CF hood but painted dark blue. Able to remove the paint & CF looks very new. Thanks for the paint guy. He done a very good job....
YEN96,
Are you referring to a guy selling of his EG CF hood painted white color in Spore? Hahaha...:biggrin:
Sand the paint down, then compound and polish to give it a nice finish. Not sure if can use thinner instead of sanding...
you can do anything with the CF,...
u can sand it down,... thinner should be quite risky, later melt the epoxy haha,...
one thing you can see after the paint layer is being removed,... whether the CF is "cooked" or not,... meaning some patchy different tone everywhere,...
if cooked,... you continue sand until nipis also no use,...
and you are not able to lacquer the CF,... it wont stick long,... at least mine acted that way,...
lacquer and the CF epoxy have different expansion/contraction/shrinkage,... so they will divorce in say,.. a week or two. Unless some paintguy can come out with someting that make those two material bond/kahwin/etc,... then nothing can save it.
if you sand it down, and get a good tone and uniformed tone,... just leave it like that.
another option,... install the CF lookalike "cloth" sticker,...
i still prefer the original CF clear (3d look,... fibre cloth visible in between the epoxy), but if no choice,... wat to do,..???
else, paint it the color or your car, but make sure the paint also good type, can bond/kahwin, or else your paint layer later also peel off,...
u all sound so confident hahaha..confirm can ah restore back ?..will it be expensive if send to spray shop to do ?? cost how much...RM300 can settle ??
can the bonnet put inside eg6 car ..can go in ?
ok, corner of the hood, the paint chip off showing CF base, now i not sure the whole bonnet, the base CF got damage or not ....How ??? can CF be repair if crack or wat ........
