Nut
samngcheesan
As per subject
This nut is loose now and I unable to tighten the screw
The thread of the nut still ok
How ah?
re-thread, if kenot, just use a longer bolt + additional nut
**if u just mean that the bolt's thread is screwed, then easylah cari new screw
OHHHHH finally i get it..... basically the 'nut' on the plate is loose and can spin freely?
if you use glue/nail polish takut takut when wana take out, shit happens and it gets stuck
why not try soldering it in place?
if its important..very2 important...just bring it to the welding shop which has an ac/dc tig welding machine, since it is aluminium rite?
unable to hold it as is inside the air filter box
---------- Post added at 08:45 AM ---------- 6 hour anti-bump limit - Previous post was at 08:44 AM ----------
unable to weld also because the nut is steel and the plate are aluminium
