Need some input frm ZTH members!
nwar
Guys...I have a question.I'm sure a lot of u are familiar with voltage stabilizers and grounding cables rite?Ok...so I've put these 2 things into my car(proton satria) and at first it did stablize the voltage hence not much lose on horsepower.After 4-5 months somehow i've experienced the fluctuation of voltage and lose of power again but only this time it's quite a lot.my headlights flicker for a nano second...it wasn't like this b4.so....wat's the problem???is it the voltage stabilizer rosak???pls care to give some advice....thanx!
just remove it & test, its not that hard
label the cable first before removing it
or go check ur battery connection & test ur battery at battery shop, they got the instrument to tell you if the battery gonna die....
sometimes your alternator wanna kaput
yea....most likely it's the battery.that's wat my guessing was.thanx guys!!!any more possibilities???
