Voltage Stabilizer recommendation
mlanun
Hello All,
I'm new here.
Need some advice and suggestion for voltage stabilizer.
I have looked around and found 3 voltage stabilizer that suits my budget.
1. zaptor, silver or gold
2. deizin
3. k2 power
Deizin VS includes grounding kit for almost the same cost of zaptor gold.
One thing that draws me towards zaptor gold is the waterproof feature and 1 year warranty. Deizin only carry one month warranty.
I could not find anything on k2 power voltage stabilizer.
Genuine Pivot Raizin is out of my budget.
I would appreciate any input about this.
actually, all the voltage stabilizers are same one... the different is brand and model.. and u even though can DIY if u are electronic back ground people.
Btw, u can feel the different after install ... but not for all engine.
Thanks for sharing.
How about the quality and durability difference?
I wouldn't want it to die so fast on me.
I still recommend Pivot Raizin.
if you shop around, you can get the original for under RM300, inclusive of installation.
But be very careful regarding imitations. I've seen plenty in the market.
check out Pivot's web site on how to spot imitations.
using raizin vs.......not bad...but works mostly on the headlight dimming only.....not a performance upgrade woh.........:_:
my clock become blur when switching on the light, headlight also sometimes blinking, do i need vs or my batt was weak?? so far no prob to start my car..
thanks guys for the input.
k2 or denzin is bad......denzin is the fake 1 from Pivot raizin & its made in Tw...
JINEIL2EN, could you explain how bad they are? I know deizin is the imitation of Pivot Raizin. It's good if you could share your experience.
I'm not sure if it is really worth it to spend more to get Pivot Raizin. Zaptor Gold seems to have quite a good reputation.
the best way is to borrow a vs from ur fren (if he got) n instal to ur car....then u will see it works o not...the cheaper way la
hehe
1st of all, how much is K2 and Deizin?
i guess the price is slightly cheaper than pivot or zaptor only.
for Pivot, u hv to get from N1 Racing located at sunway to prevent any imitation unit.
since there is an original product out there, why wanna take risk to test the fake/imitation one? it may not bring you any effectiveness perhaps.
so far in the market, the most common we can see is pivot blue n zaptor.
my2cent
my2cent
haha..good thing are not cheap, cheap thing will effect quality...
imitation...sucks...hahaha...
I agree with Vagabond..get either Pivot Raizin Blue as it is the most value for money voltage stabilizer in the market. You can install the Pivot without the ground cable first(RM150). Then install the ground cable when u have the budget.
I have it on my car and it does improve the lights and starting.
.... just don't end up a Pivot addict like me .....
.... first it was the blue .... then the red .... then the yellow .... then the black ... then spark earth .... then ignigtion earth .... then the 3-stage shift lamp ..... then then radiator cap .....
PIVOT ROCKS!
Does it do much difference for VS between with and without grounding cable?
For the cable, any specific brands that I should look for?
TIA! :_:
yea me too, now searching for better 1 volt stabilizer..
1 more question, what is different between included grounding cable & without grounding cable installation?
thanks
simple....just spend some money on it, install it follow all the instruction...make no mistake....after 2 weeks, i just an routine to checked my water level, saw the inside of Denzin seems like been burning b4....wah...the Denzin is buring b4....without any warning....so scary now...dun dare to buy those imitation product liao....especially electronic stuff.....
