Need Help urgent.
Blowfish
Just recently, I have been facing difficulties engaging gears. ( driving a manual proton). Even when i step on the clutch, i have problems engaging into 1st,2nd and reverse gear. (3,4,5 seems to be fine). What could be the problem? If it was the clutch then most probably i would difficulty in engaging all gears right?
I'm bloody worried it could be my gearbox? I really need some help here. Sometimes to engage into 1st or 2nd gear, i actually have to enter 3,4,5 first.
I'm actually driving a 1.6 proton. If it was the gearbox, how much would it cost to change one? I don't think it's the clutch coz it doesn't seem to be slipping.
Stop your car stationary and try to engage every single gear. If is fine then your clutch pump, bush and oil are fine. Start your car and drive along the road, engage every single gear level. If problem remain, it could be clutch plate worned.
hope may help.....
Do you suffer from any power lost ?? It could my your gears sycronizer's problem its function is to provide easy and smoother gears changing.
