Need Help : Hard to Engage Gear
aja
4,000 RPM
Guys,
I just change my clutch plate only (standard to standard) like 2-3 days ago. Now, my manual gears are hard to engaged. Sometimes when standstill can't engage at all. Have to switch off engine & push the clutch paddel few times, then baru ok.
First thought was insufficient gear oil. Already checked. Enough!
Later, I was thinking to bleed it in this evening. Hopefully, this can solve the problem!.
Anyone have experience the same problem before (on Honda)?.
does your clutch feels pressure-less? (sotong feeling) if it is like sotong.. that means there are some air trapped in your clutch fluid system. Bleed the clutch and re-try. The other problem may be wrong installation of the clutch plate which is unlikely.
