Need help!! Prevent auto Hibernate..
Bad^kokan
i just got my boardband...
in some matter..i wan to getting..on 24 hour..
my case is......when i come back from home..after work..
my pC auto hibernate..( i guess)
but..when i press the on button..
it auto resuming..back..
n reconnected to server again..
If there anyways i can switch off the auto hibernate?
so i can 24 hour onward online..
i am using Window XP..
plz HELP!!
really appeciated!
Goto Control Panel
Goto Display when it loads it will show Display properties
Goto Screen saver
Goto Power
change everything to Never
you can then click Save as
use any name you like I prefer to use Always on
click Ok
You're done.
Settings will be active immediately if not reboot your pc.
FYI:
You don't have to mess with anything in the Hibernate tab.
Leave it as it is.
Incase you wanna manually hibernate your computer those settings will prove useful.
