Need help .. Auto flip side mirror for SEG
Raymond_Hu
I just get a pair of auto flip side mirror and do wiring from an accesories shop but there is a problem they cannot solved. Both my side mirror can adjust up/down/left /right but it can only flip the right mirror when the button was pressed. Left mirror cannot flip. when the wires are connected to the relay, there is sound "tttttttttttttt" from the relay but the mirror does not flip at all. The wire can flip when the wire direct connect to batery 12v.
Anybody knows what is the problem and how can solve it. please help .......
means from relay/switch?
direct to battery --> right and left can flip
from relay and switch --> right can flip, but left cannot flip. the relay got sound "tttttttttt"
I was suspect the wire is not thick enough since left side to relay is longer distance. The voltage drop will bigger then right side. Any comment?
Raymond.. I have the same problem as well... Right mirror can flip but left cannot flip.. I thought the mirror motor is kong ... so I disable the feature... so if there is a solution we can come out from here.. then it will benefit both of us ... wuahahah
I tried to connect the right mirror to both side of the relay and it works well
but when connect the left mirror to both side of the relay, it only sound "tttttt" can cannot work
