need help for my 4g93t
wongsengming
my 4g93t gsr (manual) gt these few problem:
1. cold start, rpm less than 500, after engine warmed is look alright
2. engine is warm, when switch on the a/c or headlight, rpm drops heavily
sifus/ seniors, any advise?
thnx
wht ecu r u running
if u run a mitsu then ur isc is having probs
if u run toyota then ur ficd is having probs
normally when u turn on the key, you should hear the cit..cit sound from your throttle body area.
ISC is located at the throttle body.u can replace it by changing the whole set of throttle body or juz the ISC gear. it will cost you somewhere not more than rm300.or u can by pass it by using FICD from superchager engine.i got one unit of FICD to let go if u want it.
