Is it normal or a problem for my car?? need help!!!
peterj
Hii all brothers and sisters, my car is a wira with mivec turbo engine..... before emanage tuning, anything is fine except i cant rev too high and really bad fc..... but after the tuning, i m not used to the car because
1.) i usually press accelerator slow and smoothly, but now seems like a bit is not enough to start to move the car in 1st gear.....even rpm till 1.6k ...... the car some times seems jerking and wanna die off... i sometimes have to blow 1st b4 move(this is wat the mech tell me after the tune).....
2.) early in morning,when i start my car, even without aircon, the rpm seems up and down very frequently and the amount of rpm drop and rise is big also.... this morning i make it idle after start, the rpm suddenly will drop to 400 or 500 and wanna die of..... so i hav to step paddle to make it rise and after few minutes and the engine hot.... then it will not like that,rpm will maintain at least 800-900....but even it is hot, the rpm sometimes will also up down a bit and experience a bit jerking when drop lower then 800.......
can anyone help?? :adore: is the fuel to little after the adjustment after tune so i hav to give more fuel during move? i fed up when i wan to move my car in traffic light, my car wanna die of and jerk so i hav to blow a bit like wan to show off.....damn..... sometimes if traffic really jam, i will be horn also due to being too slow.......i nid advise and help pls :adore: :bawling:
ohh, i didnt notice u r in kuching.. id suggest u do a compression test first before speculating further.. it may be the tune, or it may be mechanical. the comp test will determine whether the mechanical is okie
rpm up n down normally is the ISC or TB dirty/problem...get it clean or fix 1st before proceed to next step
