Nakamichi PA2004
ICE -In Car Entertainment
Nakamichi PA2004
csy
2,000 RPM
Continuous Power Output
Power Output (4 ohms) 100 W x 4
Power Output (2 ohms) 200 W x 4
Power Output (1 ohm) N/A
Bridged Power Output (8 ohms) 200 W x 2
Bridged Power Output (4 ohms) 400 W x 2
Bridged Power Output (2 ohms) N/A
*Two mono amplifiers bridged
Minimum Speaker Impedance 2 ohms
Power Bandwidth 5 Hz - 30 Hz
Frequency Response
(1 W / 4 ohms) 5 Hz - 100 Hz
Total Harmonic Distortion
(at rated power, 4 ohms) Less than 0.05%
Intermodulation Distortion Less than 0.05%
Input Sensitivity 190 mV - 8 V
Input Impedance 22 K
Signal-to-Noise Ratio
(minimum sensitivity 22 kHz bandwidth filter) 103 dB
Stereo Separation (2 kHz) 80 dB
Damping Factor (20 Hz, 4 ohms) More than 150
Phase Shift Control Yes
Auto Bridging Yes
Line Output Yes
Dimensions 284.8 (W) x 66.4 (H) x 450 (D) mm
11-1/4 (W) x 2-5/8 (H) x 17-3/4 (D) inches
Mass (approx.) 9.09 kg / 20 lbs
Crossovers*
High Pass 68 - 4.1 kHz*
Slope 12 dB / octave*
2nd Low Pass (channel 3+4) 300 - 4.1 kHz*
Low Pass 33 - 200 Hz*
Slope 24 dB / octave*
Bass Boost at 42 Hz Yes*
Phase Shift Control Yes*
big and clean power,2way and 3 way active ready,handcraft in USA
missing the silver plate cover
sold
reason for sell: upgraded.
item use less than 2years,as image attached.
call/sms 016-3835170
dealing location:-kepong,selayang,pj.....kl,selangor
