dls ca22
ICE -In Car Entertainment
dls ca22
ee27
Number of channels 2
Amplifier class AB
Mono bridge mode 4 ohm 200 W RMS
Output power in 2 ohm 2 x 100 W RMS
Output power in 4 ohm 2 x 60 W RMS
Damping factor >100
S/N ratio, A-weighted >100 dB
Frequency range 10 Hz - 35 kHz
Input sensitivity 0,25 - 5 V
Input impedance >10 kohm
Input impedance, high level 100 ohm
High pass filter 15-500 Hz
Low pass filter 50 - 500 Hz
Low level output Yes
High level input with auto start Yes
Power consumption (idle) 0,5 A
Power consumption (max) 25 A
Rec. power cable Minimum 5AWG / 16 mm2
Fuses 1 x 25 A
Dimension (W x D x H) 70 x 230 x 268 mm / 2,92 x 9,06 x 10,55"
Weight 2,7 kg / 5,95 lb
nice sound for
