myvi rim offset...
Naim
to all sifu...I planning want change 16 inch rim at my Myvi..
target japan rim 16X7jj offset ???
dont know what the best and nice offset ??
and the nice tyre saiz???
if u planning to lower your ride get tyres 195/45/16 or 195/50/16..would be the best choice..if u get the right offset maybe 38-42 than u can try using 205/45/16...to avoid hitting the fender use 195/50/16..best choice..
myvi's offset is 38 - 42..so it wouldn't be any problem if you try 16" with 205/45 profile tyre..:proud: and try to find the correct offset
bro i use 205/45/16 tyre and my rim offset is 45, i plug in myvi, but got problem la coz my tyre hitting my suspension. but its not hit to much la..very2 closed...so what is the best solution..
I use this setup 205/45/R16 , with lowered spring it will hit the fender. :-(
not the inside, but the outer part
best choice is using 195/50/R16....just nice:burnout:
yup bro..
im using eibach sport spring.
If you drive alone or 2 people inside the car, it really nice setup.
But if 4 people in the car, it starts to hit the fender already. :(
im using d2 adjustable with 17" with 7inch wide and +35 offset..
215/40/17 , lower with 2 finger.
without any problem when 4 ppl inside the car~
