Help ..having problem with offset
Im driving a myvi and currently running with 16"wheels with offset 40.My problem is the outer side of the tyre is scrapping my rear wall if i drive with 4 pax.should i change my rims?is offset 40 too much for myvi?should i change to offset 38 instead?
help XXX
im already using GAB springs with Improve absorber..I need to know what is the best offset for my rims..should i change to offset 42 rims or lower to 38 offset rims.
bro, what size of tires u r using? if u r using 205 series, then u will need to increase ur offset...not decrease! by using +45, it should clear everything. btw, whats d width of the rims?
the cheapest way is to lipped ur rear fender. u should gain extra 10mm clearance.
currently m using 16/50/205 series tyres, so u are saying i should look for rims that has offset above 40? is 42 good enough?
because i tot of swapping my rims that have offset 40 with a rim that has offset 42..currently that rim is used on a satria.how,can ah?
---------- Post added at 05:19 PM ---------- Previous post was at 05:17 PM ----------
but guys..myvi rear fender not much to lipped in.very minimal..lass then 1inch,makes no different
Re: Can i still use rubber damper with my GAB sport spring?
i have a question
Can i still use the rubber damper that can harden my ride? currently im using GAB spring. I need to harden the ride because my rims offset are abit off and if i carry 2 person at the back it will scratch the tyre..
can the rubber fit into lowered spring or is it only for OEM spring?
opinion please......
the rubber damper wont help u much, change to offset +42 rim or send to body workshop to press out a bit your rear fender, offset +42 is enough already or use 205/45/16 tire, offset +45 for rim 16" is not easy to find.... my opinion = go to body workshop to press out a bit your rear fender, don worry, they can do it without damage your body paint....
the prob is u r using wrong tire size . myvi is suppose to use 205/45R16 tires. not 50 series with the rite tire, +42 rims also no prob...
