Myvi 1.5 SE Modification
Thank you all for the feedback. What I learn is you cannot have better power and good fc. So its a win-win situation.
Like what fcx- said, I think ill go for UR front strut bar, and maybe underbrace later on, and adjustable + new set of tyres and rim.
Thank you all for the feedback again, appreciate it a lot. :-)
Just need another feedback on new set of rims and adjustable. I surveyed a lot of rims and thinking of installing P1 Racing Buddyclub rims but most of the brand new ones is around RM 350 - 450 and I think is kinda cheap. Is it the Taiwan made ? How is the rim compare to the one more then 2k+ (Second Hand) ? And also what is the recommended size for Myvi 1.5 ? Im thinking of 16"
And also need help on adjustable, which one will suit Myvi 1.5
All those cheap rim are imitation.
some AAA grade are almost 80-90% like the ori rim.
entirely up to u to choose,if u can afford it then u can buy the ori rim.
if u go 16inch the the tire will be thinner hence the ride will be a bit more uncomfortable.
on the adjustable,the main thing is the spring rate.
If you don't mind the bumpy ride and more expensive tyres then go 16" which also look much better, but the 15" will be cheaper for both rims and tyres. Ride also much better.....
check properly when buying ori used rims. I had a fren whom he thought he gotten a pretty good deal with ori VR rims. Everything looks nice after refurbished. polished and painted and all. After 1 month of usage, the fine hair crack showed up......sent to tyre shop and found out the rim was being repaired before....Really chialat!
Yup, heard before. They weld and machine back......:banghead:
