u mean the same like the original? or harder than original?
Try APM performax (red) absorber and just use back your original spring black. No need to buy APM performax spring (red), sux low and bumpy. Don't change to adjustable, very hard compare to stock. Case close.
Short stroke abs + original springs isn't that good a combo la.
2005 Wira SE - does it have the shortened fat front springs or has it been changed to the standard 1.6 springs?
If you want comfort with some degree of performance consider the Improve Comfort absorbers paired with the original springs.
If you're not into performance at all and want pure comfort - stick back to Kayaba ori absorbers with original springs.
If you have a lot of money to burn, consider Koni absorbers + Eibach springs.
