AE92 convert to 4throttle
hello86
hi all , may i know my car AE92 SE LIMITED , i want change silvertop 4throttle !
if i want change the ae101 gearbox 5 speed , my flywheel have to use 101 o 92 ??
my drive shaft need modify ?
n ae92 how 2 use ae101 absorber ??
Just buy an complate 4age 20v Silvertop with gearbox and wirring and ecu.. than is ok liaw... installing the gear box on ae92 is not a problem...just the gearbox mounting has to be change only...small matter...will b no problem for a good mechanics...as for the flywheel...no worry my friend...everything complete just dump it into ur engine bay..no problem...
Ae92 can use Ae101 absorber..no problem...all things are interchangeable... kekeke... tat's why i love our AE hahahaha
now my gearbox is auto 1 , i wanna change ae101 manual !
so i nid change the ecu ??? izit auto ecu n manual ecu is not same 1 ?
If ur 20v silvertop is an auto gearbox than u change to manual gearbox...u can still use back the Auto transmission ECU.... but is always advise to change it to a manual ecu... bought ur transplant already?
so tat means i stil can use back my auto ecu ?
hav any diffrence ? if i use manual ecu n auto ecu !!
bought already ....
