Multi Function Jump Starter
vr2turbo
((( God Level 30,000 RPM )))
Helmet Clan
Moderator
Hi guys,
Lately having problem with my car battery. The battery having parasitic drain. Send to wire man also cannot locate the drain. Off alarm, take out HU etc. still draining. If don't drive for 3 days the battery will be drained until cannot crank the car. If use daily then it is okay.
My car is manual and have jumper cables, means can push start or jump start but then when alone both also useless.
Then made research and finally ordered a Multi Function Jump Starter. Sort of a Power bank but capable of cranking up a car. Was delivered yesterday, charged it up and made a trial today.
Remove the +ve positive terminal from car battery, therefore no more power coming from the battery. Clamp on the wires to +ve and -ve terminal, plug into the power bank, alarm went off, means voltage pretty strong. Turn on the key, instrument panel lights up. Crank and car started. Shut down and tried again and started.
Initially was quite skeptical that the power bank have enough juice to crank the car. So having tried it myself, therefore just sharing this with you.
Here are some pictures.....
Comes in a nice bag
Power bank comes with jump cable, laptop cable, phone cable, AC charger, Car DC charger etc.
Hook up for trial start
Instrument panels lights up, and alarm went off....
Bank rechargeable ?
Yup, just like our hand phone power bank. Rechargeable and have output for 5v (hand phone), 12v (automotive), 19v (lap top), and 12v for cranking up the car
---------- Post added at 04:11 PM ---------- 6 hour anti-bump limit - Previous post was at 04:10 PM ----------
Never say. I was selling ma.
Never saw it in your shop mah!, but anyway just only I needed it, just in case. All the while rely on my jumper cable......:biggrin:
---------- Post added at 04:13 PM ---------- 6 hour anti-bump limit - Previous post was at 04:11 PM ----------
How much u got it?
I search and most selling RM200 plus, got RM199 also for 12,000 to 14,000mah. This one got from groupon 15,000mah for RM168.....:biggrin:
vr2turbo,that is some very "juicy" jumper.
I wonder it can be used to sot-sot people....:biggrin:
ha! ha! sot sot people need much higher voltage.......:biggrin:
There is a LED bulb at the side that can be switch on as a torch light, fast blinking light and slow blinking light.....:driver:
Cheapest way, if car breakdown and cannot start. Call Vr2turbo bring his charger :rofl:
You forgot my service and transport charges.......:biggrin::biggrin::biggrin:
---------- Post added at 06:42 PM ---------- 6 hour anti-bump limit - Previous post was at 06:40 PM ----------
that is indeed a very handy piece of gadget....
Any idea what is the batt cycle count?
Box mention 1000 times but Made in China product, okay, so true or not.....hahaha:biggrin:
well, 1000 cycle count or not, at least the jumper does the work for you bro VR2turbo. No need to pay tow truck, or getting "slaughtered" by mech if car cannot start.
Actually, I have jumper cables in all my cars, but as explained earlier when no car around how to jump, and even though manual cannot push alone....heh! heh!
So after seeing the youtube demo, decided to try and it works, so this I guess is good investment....:driver:
