Engine won't start
art806
Guys,
My car wouldn't start today. Bunyi klik, lampu warning kat
dashboard semua padam, spark melompat within the +ve clamps (between the
gap where we tighten the nuts) with a bit of smoke. Check the battery
terminal, fuses and everything seemed ok. It happened after I installed a
power amp. I took out the live wire for the amp from the +ve battery terminal and
the engine would start.. Just now I tried to start again, same thing
happened, a click and all warning lights went off. The +ve clamp of the battery felt warm although the engine is cool and not running. Is that a sign of short circuit?
I don't think the audio installer messed around with the wiring apart from joining the live wire for the amp directly to the +ve battery terminal. What could be the problem? BTW the battery is only 4 months old.... Thanks for any help.....
Sounds like you have a short circuit problem because you noted that everything is fine after you take out the power for the amps.
last time i couldnt start my car due to some dead fuse happen in my fuse box...replace it liao ok...got also many prob related to startin engine...spark plug,battery,wiring...good luck
I think the "click" noise is coming form the starter motor, on my opinion, u should check on ur starter motor.
Somebody suggested this;
There should be a fault in your electrical system.
> Usually a "click" sound without engine starting could
> be your starter motor not working. First of all you
> need to isolate the cause of this problem.
> When you turn the key, does the battery light come on?
> Or any lights on your dashboard? For new cars with
> ECU, don't turn the key all the way yet, turn on the
> elctrical system only (halfway) and let it run the ECU
> self test. You should see a few LEDs on your dashboard
> turning on, some blinking then going off. After the
> self test there should be 2 lights left only, your
> handbrake light and your battery light.
> Before we mess more with the car, I'd take the amp out
> and get it checked first. It may be faulty and cause a
> short circuit. Is the fuse to the amp okay? I mean the
> external fuse, which should be installed close to the
> battery.
The fuses (amp, radio, starter motor, ignition) are all ok, relay, I haven't checked cos don't know how to do it. This morning the car started again but I'm waiting to see if the +ve terminal will remain warm long after the engine has cool down. I still feel the power amp has something to do with it...
After about 4 hours, the car is ok now. The engine will start but whenever I connect the power amp fuse and switched the radio on, the rpm is erratic, running between 400-800. Guess the amp is at fault then. Do you think I should do an electrical test to see if any relays are affected?
