gsrTurbo9166 said:if u need power then upgrade to 1.8 mivec
juz change the engine block to 4g93
then do set the setting for ur ecu
set when the mivec kick in
piping muz hv the correct size to suit ur car cc so that there wil hv no any lag of power
high cam n performance cam shaft wil help
a fully balanced engine will help u to increase the power oso
then if u still feel underpower bolt on turbo or supercharger or NOS will definitely help u a lot
but bare in mind that mivec will never will a vtec in standard condition
sometimes mivec will full also hard to win vtec(this is my experience)
so wat car u r driving
ZamS said:Hi,
Can't remember.Rasanya aroung RM1000++. Change 1.8 block GSR/Putra, bigger T.B, bigger injector. Did it at Hyperevved. Good tuner.
ZamS said:Talk about mivec-md, all 4 piston will run at any rpm but.... only 2 injector will inject the fuel when driving below 3k rpm of +/-90km/h.
MD will kick twice?? yes correct. but only when you drinve at slow acceleration. Just about 2k-3k rpm. Can feel it at 1st & 2nd gear. Sometimes at 3rd gear. Anyway, i'm very puas hati with my engine.....
