mitsubishi Airtrek
mitsubishi Airtrek
chan_4g93
mitsubishi Airtrek fully loaded 2200cc
Mitsubishi Airtrek 2.0 turbo
Modification this car more than RM50k ......
Exterior :
* DAMD front bumper
* custom body kit
* new paint
* HID Lamp
Interior :
* pivot turbo timer
* Boost meter
* 2 Din panasonic touch screen DVD player
* sound system
* tinted
Chasis & Suspension :
* new 17inch sport rim
* Toyo R1R 215/40/17 tyre 90%
* 4 pot gto brake caliper
* new sport brake pad
* new steel brake hose
* new DND adjustable absorber high low soft hard
* new front lower arm
* new engine mounting
Engine :
* 2.2 stroker kit 2200cc
* Original HKS mushroom air filter
* new turbosmart external wastegate
* new valve seal
* new ACL bearing
* new piston ring
* new oil squiter
* new oil pump
* new garett ball bearing turbo GT28 (can boost up to 450hp)
* new emange with ignition and sub-injector control
* two new sub-injector
* fully crank shaft balancing
* banana turbo manifold
* jasma japan muffler
* ps- power sport blow off
* new cometic gasket
* gearbox oil cooler
* Evo 7 cam
* new work adjustable cam pulley
* new work adjustable fuel regulator
* new walbro fuel pump
* upgarde gearbox to stand high horse power
* mine's ECU
* front mount intercooler
* stainless steel intercooler piping
* new iridium spark plug
* every 5000km change fully sythetic engine oil
* every 10000km change motul AT and Gearbox oil
* fully engine re-built
* on wheel 3++HP
* everything just done on june 2011
* test to believe
* Very Powerful & nice car
* View to believe
* want to sell fast, call for nego and test drive
* nego until sold
* thank you
* Mr. Chan
~bump
---------- Post added at 01:33 PM ---------- 6 hour anti-bump limit - Previous post was at 10:41 AM ----------
~bump
---------- Post added at 06:40 PM ---------- 6 hour anti-bump limit - Previous post was at 01:33 PM ----------
~bump
~bump
---------- Post added at 02:34 PM ---------- 6 hour anti-bump limit - Previous post was at 10:28 AM ----------
~bump for nego
---------- Post added at 06:49 PM ---------- 6 hour anti-bump limit - Previous post was at 02:34 PM ----------
~bump
---------- Post added at 10:22 PM ---------- 6 hour anti-bump limit - Previous post was at 06:49 PM ----------
~bump
~bump
---------- Post added at 12:59 PM ---------- 6 hour anti-bump limit - Previous post was at 08:37 AM ----------
~bump
---------- Post added at 04:43 PM ---------- 6 hour anti-bump limit - Previous post was at 12:59 PM ----------
~bump
---------- Post added at 08:35 PM ---------- 6 hour anti-bump limit - Previous post was at 04:43 PM ----------
~bump
---------- Post added at 10:54 PM ---------- 6 hour anti-bump limit - Previous post was at 08:35 PM ----------
~bump
~bump
---------- Post added 09-01-2011 at 12:12 AM ---------- 6 hour anti-bump limit - Previous post was 08-31-2011 at 07:36 PM ----------
~bump
~bump
---------- Post added at 07:40 PM ---------- 6 hour anti-bump limit - Previous post was at 04:09 PM ----------
~bump
---------- Post added at 11:52 PM ---------- 6 hour anti-bump limit - Previous post was at 07:40 PM ----------
~bump
