Subaru Impreza V8 (M)
luno
Engine
V7 STi Engine
New ACL RAcing Bearing
V8 STi Intake Manifold
V8 STi Throttle Body
V8 STi Injectors (Pink)
V8 STi Coil
V8 STi oil Pump
V8 STi Water pump
VF 30 Turbo
Aftermarket Turbo Actuator (Larger)
Front Mount Intercooler
HKS SQV Blowoff
Custom Made Oil catch Tank
Power Kevlar Racing Belt
New Alternator
Tomei Fuel Regulator
Aftermaket Aluminum Radiator
Samco Hose
NGK Iridium IX Spark Plug
Service Every 5K with Lucas Sae50 Racing Oil
Transmission
V7 Sti 6Speed Gearbox
V8 Sti Rear Axle
Exedy 4Puck Racing Cluth
Long Shaft Just Change New Bearing
Use Only Lucas Racing Gear Oil L9/L10
Handling
Gab Hi-Low-Soft-Hard 32 point Adjustable with Zeal Pillow ball Mount
All Bushing Change to SuperPro
Auto Foam Chasis Stiffening
Front 4pot Gold Brembo
Rear 2pot Gold Brembo
Just Change Front Rotor (Ori)
Project U Front & Rear 550 Brake Pad
Project U Brake Hose
Ultra Racing Room Bar
Ultra Racing Rear Sway Bar
STi Front Strut Bar
Ecu
V8 STi Full Wiring & ECU
Interior
V8 STi Meter
Apexi Turbo Timer (Ori)
Defi Oil Temp,Oil Press,Turbo (Ori)
Exterior
V8 Ori Head LaMp
V8 Ori Rear LaMp
V8 Charge Speed Bodykit
Basically this is V7 Conversion To V8
Engine just Rebuild
New Piston
New ACL Racing Bearing
All Seal & Gasket Change
No worry for any Oil Leak
No repair Need
100% No Accident Before
Loan Provided
Price: RM 89 000 NEG
