Maintenance: Battery
BS,
I didn't know that GP is from Korea. Actually I don't mine where is it from or how it looks. As long as it last longer for my coupe to hibernate then it is okay. I was told by my mechanic this is one of the highest amp MF battery with 65amp and very close to DIN66 of 66amp capacity. But not very sure on how is the cold reserved charged compare to DIN66. Anything higher is either OPTIMA series battery or those use by Mini Lorry. Both have the huge amount of reserved amp to start your car even prolong unused.
BS,
How the performance of your DIN66 series? How long did you use already (months?) How often did you start your car? Usually when the battery is new, shouldn't be any problem even 2 weeks also didn't start. But after 3 or 4 months. You will have weak battery.
Better warm up the car every 3 to 4days without using.
If the load cycles of the battery are frequent, the battery will worn out very fast.
Ace said:
BS,
Frankly. the Yokohama DIN66,
so far longest period i tried is 5 1/2 days. No problem (touch wood).
And I realise my starter crank 1 more round compare with the older battery.
Previous DIN55, *crank* *crank* *crank*, car started
Yoko DIN66, *crank* *crank* *crank* *crank*.
So far so good for me, many years liau, also change many liau, last for about ngam ngam 1 year to 1.5 year
Thats why it is advisable to drive your coupe out every 3 days or so. BS you better do that or your battery will cong fast. I now exercise my coupe every 3 days driving out to work.
Yu,
You won't be having problem with the battery as you drive out everyday. You will maximise the usage of the battery. In another word. You are more worth it of owning the battery. Me and BS is a waste of battery hehe.
Actually there is a way to remedy the problem face by Ace and BS.
Just disconnect the battery when the your coupes are hibernating.
Daniel,
I actually thought of that also, even was thinking of plugging out the 100A fuse that link all the power. But then again too many time of plug unplug or screw unscrew will make all the connection loose mah.
The price of maitaining a weekend or second car = petrol to warm up + quality shampoo & wax/polish paste + tyres + battery + quality cover
So pricey.
Ace, BS,
did I miss anything in my list ah? :)
Nope..well highlighted! :biggrin: You got us there.
So pricey.
Ace, BS,
So pricey.
Ace, BS,
Plus, Weather will determine your ride... Am I right, Ace. :biggrin:
Actually if we seldom drive, will it affect other moving mechanism in our car?
I seldom drive when I'm having long holidays.
Normally refill 5 to 8 times of fuel every month but during holiday period, only refill one or twice per month.
Yupe, only when holiday seasons. hehehe...
That's why I'm always asking for gatherings so our coupes can come out for some exercise. ;)
yaloh, I'm maximise the usage of the battery, I start my car about 20 times a day & is every day.
If about a week not starting the car & the battery is out of order, than must be some thing wrong, may be electric leaking or the battery is not good. Last time I use my brother's car for about 2 months time, & my coupe is park with out starting for about 2 months, still very good in starting.
What's the function of a start relay?
I heard that our start relay easily malfunction.
Can show me the pics for a Coupe start relay?
If starter problem then you won't be able to start your car at all. You can't even hear a click.
Yu,
If you battery is new or fully charge and daily driven and suddenly not drving for 2 weeks is still okay. Try driving only once a week for 2 or 3 months and you would know what I mean. That is why those new Hyundai Car all proudly stated that their car comes with a Motorola microchip that able to shutdown and conserved battery when long period not using. Take one brochure from Hyundai showroom and you will see what I mean.
A mechanic told me that if you just install a new battery and in 2 or 3 days not using the car and no battery charge then it might be the relay is draining the battery. It might be like what you said that it may be the faulty battery also. My local accessories shop boss also told me that if there is a short circuit on the wire. The car won't be draining battery it will blow your fuse one by one. He also confirm that if you didn't drive your car often for one week. You WILL drain the battery out of juice. Fuel injection car consume more electric juice then carb engine. Thats why I'm still happly keeping my Satria.
Since you guys are talking about relay. FYI, I already change both relays on my car. One at the engine bay and another inside under the driver side where it is called MFI relay. This thing is running very hot when it is on. Actually I also change a few relay on the engine bay also. Only the starter relay I'm using ori from Hyundai (OMRON brand) damn blady expensive. If cost me RM50 for one where the rest of the relay I outsourced and got it for RM14 only.
